Netflow Collection Engine - performance
p.lubinski
I want to plan deployment of NFC, I dont know how to estimate a performance of single NFC. Do You have any expirience how to consiger how much of flow can be handle by one serwer with Netflow Collection station.
Ragards,
Pawel
mchin345
Level 6
Level 6
There is a clear note in the following link for the system requirements :
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cns_nfc/rel_5/rel_note/nfc502rn.htm#wp41253
The CPU, RAM, and disk space recommendations above are minimum requirements, the actual requirements are determined by your configuration and by the volume and uniqueness of NetFlow data that is received. Actual resource usage can vary greatly depending on these factors.
You can have a look into "Tuning Memory Usage" chapter of the manual at :
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cns_nfc/rel_5/user/tuning.htm#wp1106698
