11-05-2012 01:57 PM
Have a Cat 4507 with Supervisor 7-E, setup configuration to send NetFLow information to an external server, everything worked great but after 2 weeks, the exporter is showing zero packets sent and the following error is at the console:
Nov 5 15:52:35.231: %C4K_HWFLOWMAN-3-NFEINTERRUPTSTATUS: (Suppressed 7336 times)module: fi InterruptStatus: 0x4
Nov 5 15:53:05.235: %C4K_HWFLOWMAN-3-NFEINTERRUPTSTATUS: (Suppressed 7345 times)module: fi InterruptStatus: 0x4
Nov 5 15:53:35.239: %C4K_HWFLOWMAN-3-NFEINTERRUPTSTATUS: (Suppressed 7341 times)module: fi InterruptStatus: 0x4
Nov 5 15:54:05.243: %C4K_HWFLOWMAN-3-NFEINTERRUPTSTATUS: (Suppressed 7344 times)module: fi InterruptStatus: 0x4
Nov 5 15:54:35.247: %C4K_HWFLOWMAN-3-NFEINTERRUPTSTATUS: (Suppressed 7341 times)module: fi InterruptStatus: 0x4
4507#show flow exporter statistics
Flow Exporter Netflow-to-Orion:
Packet send statistics (last cleared 01:08:30 ago):
Successfully sent: 0 (0 bytes)
Client send statistics:
Client: Flow Monitor NetFlow-Monitor
Records added: 0
Bytes added: 0
I can't find any information related to that error, I haven't restart the switch because this is a very critical switch on a production network and also I would like to do some troubleshooting before doing an IOS upgrade or hardware replacement.
Any ideas?
Oscar
11-06-2012 10:22 AM
I'm seeing the exact message and have not been able to find anything on it either. But I'm not running Netflow.
11-07-2012 12:06 PM
Which IOS version and Supervisor are you running?
Mine is:
Still haven't been able to find any information about the error.
Oscar Perez
04-18-2013 06:05 AM
07-03-2013 08:21 PM
Same here. We have encountered this bug with our CAT 4507 SUP7E.
Our current IOS version is: cat4500e-universal.SPA.03.01.01.SG.150-1.XO1.bin.
Netflow collector can not collect any flow from this switch anymore, and CPU of 4507 always reaches over 50%.
Did anyone also face this error? After reboot, will the 4507 and its netflow work well ?
07-07-2013 10:37 PM
I've reloaded this switch for a few days and it's worked fine since then. Hope that I'll never encountered this bug again.
01-30-2014 05:56 AM
We're seeing the same issue on a 4506E Sup7e and cat4500e-universalk9.SPA.03.02.00.SG.150-2.SG.bin.
Has this been fixed yet? CSCub56668 suggests not and CSCtq40467 is restricted so I can't read it.
