Netflow on 7200
rwilletts
Does anyone know what this message means ?
IPFLOW: Error sending export packet: Enqueued to process level
htarra
Level 4
Level 4
Could you please tell me if you have Netflow Collector running on this ?
- Or do you have any another apps to collect Netflow ?
The reason I ask this because the error message directly points to the failure of any reception of Netflow Records.
Check out this link for more info.
http://www.cisco.com/en/US/tech/tk812/technologies_white_paper0900aecd802a0eb9.shtml
Could you please do the following:
1. Turn on your netflow debugging as before.
2. do "show ip flow export" and send to me
3. once the debug error message comes up
4. do "show ip flow export" and send to me
5. Pls do an extended ping to IP Address with source IP address of Loopback0 .
This is to test the congestion between Router and Netflow collector. Pls send me the output.
