NetFlow on a 4506 switch - Sup Eng IV
Jared.Carpenter
Does anyone know if a 4506 switch will export flow data to an external “collector” without installing the NetFlow Services Card (WS-F4531) ?
andrew.burns
Level 7
Level 7
You're out of luck, I'm afraid. Netflow is a hardware-based feature so without the hardware...
Andrew.
andrew.burns
Level 7
Level 7
Andrew.
