NetFlow rmon
rdanevich
Level 4
Level 4
What's the difference between:
set snmp rmon enable
-and-
set snmp extendedrmon netflow enable mod x
When would you use one vs. the other? Can they both be set at the same time? Should they both be set at the same time?
My configuration:
Nam 2 module installed on a 6509 running Cat OS
b.hsu
Level 11
Level 11
In "set snmp rmon enable" the rmon statistics are collected on a segment basis and " set snmp extendedrmon netflow enable mod x " is used for enabling or disabling the SNMP extended RMON support for the NAM module
Thank You for the explanation.
