netflow v9 packet format
m.matteson
Level 6
Level 6
I am writing my own netflow collector to run as a windows service and do fancy things with the data it collects. one of the first issues i am running into is this.
in the netflow format PDF i obtain from ciscos site. it says that the packet header is 20bytes long. bits 0-159. one of the questions i had is this. for example i parse out the first field which is the version field. this is 2 bytes long. according to documentation bits 0 -
15 hold this value with bit 15 in the picture having a value of 2^0 and bit 0 having a value of 2^15. after rasing the bits to the correct powers and adding up the values i do obtain the decimal 9 which is what i expected. once i try to parse out a field outside of the header is where i run into problems. the header ends at bit 159 is it correct for me to assume that the FLOWSETID field starts at bit position 160 and goes to 175 (2bytes)? i think my bit positions are off or something because i was getting 14483 as a field type number. and thats not listen anywhere in the table 6 of field types in the PDF. does anyone have an idea if there is padding in between the header and where the flowset data begins?
thomas.chen
Level 11
Level 11
There is no such zeros added inbetween.The NetFlow Version 9 record format consists of a packet header immediately followed by at least one or more template or data FlowSets.Refer the following URL
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_white_paper09186a00800a3db9.shtml
