Netflow vs NDE
hank
I am wondering if I am double counting flows. Here is my config snippet
from a 7613 running 12.2(18)SXE4:
mls flow ip interface-full
mls nde sender version 5
ip flow-export source Loopback0
ip flow-export version 5 origin-as
ip flow-export destination XXX.139.197.76 9800
Most interfaces look like this:
interface Serial1/0/5
ip route-cache flow
But looking at:
gp1#sho ip flow export
Flow export v5 is enabled for main cache
Exporting flows to xxx.139.197.76 (9800)
Exporting using source interface Loopback0
Version 5 flow records, origin-as
460190792 flows exported in 15339766 udp datagrams
0 flows failed due to lack of export packet
3 export packets were sent up to process level
0 export packets were dropped due to no fib
199 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
0 export packets were dropped enqueuing for the RP
0 export packets were dropped due to IPC rate limiting
gp1#sho mls nde
Netflow Data Export enabled
Exporting flows from xxx.139.220.90 (58540)
Version: 5
Layer2 flow creation is disabled
Layer2 flow export is disabled
Include Filter not configured
Exclude Filter not configured
Total Netflow Data Export Packets are:
1018492393 packets, 0 no packets, 3766475592 records
Can I be doubling exported flows? How can I tell? How can I make
it just export a flow once?
Hank
a-vazquez
Level 6
Level 6
Also issue the command "ip flow-export ingress" under the interface configuration.
Jan Nejman
Level 3
Level 3
why do you think that flows are send more times?
Number of MLS flows is almost higher than number of flows processed by routing card (only first packet go through routing process [this packets are sent in via ip flow export command], rest of flow is switched throught MLS [exported via mls commands].
Jan
