netmanage IP
eric.loiseau
When I use netmanage and receive an event from switch or router, I can acknowledge an error but I didn't found how can I purge/delete all events.
Any ideas
trombidz1
HI ,
I am experiencing the same problem
anyone knows how to clear the status after a problem is acknowledged ?
thanks
anyone with a solution ?
David
