Netshow output from the CLI?
kevin_miller
I need a way to run a "show access-list" command on a PIX periodically so I can look at the number of hits.
I can run this command from the Ciscoworks CLI using:
./cwcli netshow createjob -u xxxx -p xxxx -device devicename -customcmd "show access-list"
This command successfully runs the job. Unfortunately, the output is not echoed, but is saved in report archive. I can have the job mail me when it is complete, but even that doesn't include the job output!
Is there a way with the "cwcli" commands to get this report, or have it echo the output, or write it to a file? Is there a better utility available to do this?
Thanks!
nhabib
Level 9
Level 9
Looks like bug id CSCsb26481: cmdoutput not shown in netshow cli
Looks like the fix will be in RME 4.0.3, available in November
nhabib
Level 9
Level 9
