Network assistant and error
tom_davis
I have cat 2950 and I am trying to use Network assistant to monitor the network and check the configuration of the switches. I currently get IOS command not found when I use the network discovery tool to locat the switches. any ideas? will the CNA also locate cisco routers?
nhabib
Level 9
Level 9
With CNA, it is critical to make sure you have the proper IOS version.
Check the CNA supportlist for devices and IOS versions.
