Network Assistant
dimensyssrl
Hi all.
I'm trying to use CNA, I've used it yet in another environment (one 4506 and many 2950), and it work fine.
Now, I'm trying to use it in a mixed environment, where there are many 2950, 2960, 2970 and a 3508.
I've read that all these devices are supported, but when I try to add them to the community, CNA reply with a "unsupported device" message.
Only 2950 can work.
Any idea?
Daniele
ahmednaas
Level 4
Level 4
which version are you using?
