Network Design
wrwiii122
Level 5
Level 5
I need some opinions from some people. I have 30 sites each have a 3550 and are connected with fiber to create a loop. I do not have them setup as routing to a single gateway. They run at layer two VLANS and if I ever need to I will route between VLANS. Is this the wrong approach? Should they all be on their own subnet and route to a gateway to get where they are going?
rdoak
Community Member
It might be helpful to see a drawing of what you are trying to accomplish, but from what I read you may want to keep each VLAN on their own respective subnets with a multiple default gateways for traffic balancing.
