04-04-2005 10:45 AM
I received a drawing with an icon in it that I've never seen before. It looks like a Catalyst 6500 with a route/switch processor above and an Si on the
switch. Can someone tell me what the Si represents?
Solved! Go to Solution.
04-06-2005 12:44 PM
Silicon Switch Processor. In doing some light research it would appear that silicon switch processors were an add in module for older Cisco devices like the 7000. It provided basically a hardware accelerator for switching as well as a dedicated hardware packet buffer.
All of the catalyst switches (to my knowledge)are "Silicon switches", although most of the time people refrain from using the Si icon since it causes clutter/confusion.
04-06-2005 12:44 PM
04-07-2005 07:20 AM
I can understand why it would be confusing.
Thanks you.
Pete
