Network permissions in ACL.
Hello community
Newbie question: I would like to read a further explanation for the following
What single access list statement matches all of the following networks?
192.168.16.0
192.168.17.0
192.168.18.0
192.168.19.0
A - access-list 10 permit 192.168.16.0 0.0.3.255
B - access-list 10 permit 192.168.16.0 0.0.0.255
C - access-list 10 permit 192.168.16.0 0.0.15.255
D - access-list 10 permit 192.168.0.0 0.0.15.255
Explanation: The ACL statement access-list 10 permit 192.168.16.0 0.0.3.255 will match all four network prefixes. All four prefixes have the same 22 high order bits. (??) These 22 high order bits are matched by the network prefix and wildcard mask of 192.168.16.0 0.0.3.255.
Wouldn't it be option C?
I understood that number 15 on 0.0.15.255 would include the all IP's starting from that number forward, but I am now sure what to think now. The only thing I can think of is to take that 3 and add it to the all IP's starting from 16 so that all IP's starting 192.168.20.0 would not be included on the list.
Daniel
M02@rt37
Hello @Daniel Céspedes,
to go further, access-list 10 permit 192.168.16.0 0.0.3.255 -- In this statement, the network address is 192.168.16.0, and the wildcard mask is 0.0.3.255. The wildcard mask is used to specify which bits in the IP address should be matched. In a wildcard mask, 0 bits mean "must match exactly," and 1 bits mean "don't care" or "match any."
So, let's analyze this wildcard mask 0.0.3.255:
In binary, 0.0.3.255 is 00000000.00000000.00000011.11111111.
In this mask, the last 8 bits are all 1s, which means "don't care" for the last 8 bits of the IP address.
Now, let's see how this mask matches the given networks:
192.168.16.0: This network's binary representation is 11000000.10101000.0001 0000 .00000000.
The last 8 bits don't matter, so it matches.
192.168.17.0: This network's binary representation is 11000000.10101000.0001 0001 .00000000.
192.168.18.0: This network's binary representation is 11000000.10101000.0001 0010 .00000000.
192.168.19.0: This network's binary representation is 11000000.10101000.0001 0011 .00000000.
So, access-list 10 permit 192.168.16.0 0.0.3.255 indeed matches all of the given networks. Option A is the correct choice.
Option C (access-list 10 permit 192.168.16.0 0.0.15.255) would match more networks than the ones you specified. It would include networks beyond 192.168.19.0, which you wanted to exclude. Therefore, option C is not the correct choice in this case.
Best regards
8 Replies 8
M02@rt37
Best regards
Thanks for  clear explanation!
Daniel
You're so welcome @Daniel Céspedes
Best regards
balaji.bandi
if the question specific to that address space /22 is the right option as per my views.
BB
Joseph W. Doherty
M02@rt37 provides the correct explanation but the value 3, in the third octet, matches 4 networks, starting with your .16.
BTW, to your actual posted question, BOTH A and C are correct.
A matches 16..19.
C matches 16..31.
If your question included ONLY matches the listed four networks, also assuming they're all /24s, then ONLY A would be correct.
yes that's right, it seems they only wanted to give access to those four hosts so option A.
Daniel
Blue_Bird
I agree with option A is the right answer.....
0.0.3.255 is the wildcard mask equivalent to subnet mask 255.255.252.0 (/22)
with /22 ....you will get block size of 4 ......available networks in 3rd octet...0,4,8,12,16,20,24
range 192.168.0.0 to 192.168.3.255
          192.168.4.0 to 192.168.7.255
         192.168.8.0 to 192.168.11.255
         192.168.12.0 to 192.168.15.255
         192.168.16.0 to 192.168.19.255
        192.168.20.0 to 192.168.23.255 and so on...
In the above question...all mention networks...192.168.16.0,192.168.17.0',192.168.18.0,192.168.19.0
will cover  5th subnet in the range which is 192.168.16.0 to 192.168.19.255
Best regards
******* If This Helps, Please Rate *******
