Network Troubleshooting
Surtie145
Hi if anyone could have a look at the linked .pkt file and point out the issues and possibly help fix it, it would be greatly appreciated
https://drive.google.com/open?id=11XINgbY_eFK50As81RHcUAWOrWShb9g1
Mark Elsen
 - This is 'problem bursting' ; please describe in an overall summary which essential problems you are experiencing (in a technical manner).
M.
The DHCP client "PC-1" is not receiving an address from the DCHP pool that has been created on Router "Inside1". Could you have a look and see what went wrong?
thank you
Hello Surtie,
I already review your simulation and corrected the problem. You had made varius mistakes:
1. When you created the port-channel you configured both sides as "mode auto". A PagP port channel never gives up when the port channel is auto/auto, you need to have 1 side auto and the other desirable or boths desirables.
2. For any reason you configured this:
ip dhcp excluded-address 172.16.10.1 172.16.10.254 so you were excluding all the IP address from the pool, and the device wan't able to share addresses.
3. You forgot to configure the "ip helper-address" command inside the int vlan 10.
Right now your PC1 is able to gain IP address. I attached the simulation corrected, so review all the thing I have changed.
Please do not forget to rate useful post, if this answer solve your problem don't forget to mark it as a "solution".
Best Regards,
