Networking
vaishkhan161190
Frequent Visitor
Frequent Visitor
Hi All,
I have Linksys N300 Wi-Fi router. i want to setup this in my small business local network.
My local network infrastructure is:
ISP>CISCO1841 Router>unmanaged switch>end user
my all end user use static IP to access internet.
IP: 10.91.149.X
SM: 255.255.255.192
GW: 10.91.149.62
DNS: 10.40.98.X
i am connecting linksys with unmanaged swith and configuring the IP 10.91.149.50 with DHCP range 10.91.149.51 to 52.
now i am connecting my mobile phone/Laptop through wi-fi with linksys, both are connecting but internet is not accessing. showing can't connect internet.
kindly guide.
Regrads
Thanks & Regards
Seb Rupik
Hi there,
What model is the linksys? It sounds like it must be a router. If it is, then I suggest you define a new subnet for the wireless clients connecting to it. This traffic should be NAT'd to the outside interface (ie WAN port), and a default route configured to direct traffic to the cisco router (10.91.149.62). The Cisco router should be configured with a static route directing traffic destined to the wireless subnet to the linksys outside interface.
...If the linksys really is just a switch, then I recommend you do not configure DHCP on it and let the cisco router manage the pool.
cheers,
Seb.
