11-01-2010 03:26 PM
We have just purchased a number of the 2960s model switches. I have one 'odd-ball' version of the switches out right now, it is WS-C2960S-48TS-S. It can't get it to sync the archive. No other device is having problems. The error states to check the DCMA log, but there is nothing of note in there. Credentials pass, but testing the TFTP fails. Any ideas?
11-01-2010 03:52 PM
Can you post/attach the display during power up? I had a DoA on a shipment of 35 2960S.
Does the switch go into ROMmon or can you get the switch to go into ROMmon?
11-02-2010 06:27 AM
The switch is up and running properly (seemingly so anyway). I discovered the problem later when I was looking at LMS and noticed there was a unit that was not collecting its config. I updated the software to it and that did not help. (see version information below).
I have now also noticed that it does not seem to understand 'ip dhcp snooping'.
Here is the switch version information:
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 07-Aug-10 23:21 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
ACCESS-202N25-2960-01 uptime is 15 hours, 21 minutes
System restarted at 17:59:52 DST Mon Nov 1 2010
System image file is "flash:/c2960s-universalk9-mz.122-55.SE/c2960s-universalk9-mz.122-55.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. WS-C2960S-48TS-S (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1431Z1G6
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
50 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
If
cisco
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : E8:04:62:1E:76:80
Motherboard assembly number : 73-12424-06
Power supply part number : 341-0327-01
Motherboard serial number : FOC14311LHX
Power supply serial number : LIT14250NQD
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2960S-48TS-S
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC14312467
System serial number : FOC1431Z1G6
Top Assembly Part Number : 800-32452-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMGK00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960S-48TS-S 12.2(55)SE C2960S-UNIVERSALK9-M
Configuration register is 0xF
