NEXUS 5000: read CPU Load with SNMP
ylvie3434
Hallo,
tried to read the NEXUS 5000 cpu load:
cseSysCPUUtilization 1.3.6.1.4.1.9.9.305.1.1.1
but there is a  timeout:
Timeout: No Response from 10.100.224.16
Other MIB values readout, like the system value, is ok.
We use snmpv3.
ylvie
AFROJ AHMAD
Hi Ylvie,
There are a few sources for CPU utilisation values from SNMP, the classic ones from CISCO-PROCESS-MIB: cpmCPUTotal5secRev     1.3.6.1.4.1.9.9.109.1.1.1.1.6 cpmCPUTotal1minRev     1.3.6.1.4.1.9.9.109.1.1.1.1.7 cpmCPUTotal5minRev      1.3.6.1.4.1.9.9.109.1.1.1.1.8 And a new source in CISCO-SYSTEM-EXT-MIB, cseSysCPUUtilization (1.3.6.1.4.1.9.9.305.1.1.1). Unlike the averaged values from CISCO-PROCESS-MIB, cseSysCPUUtilization returns an un-smoothed value and typically shows more erratic results.so  I would recommended the objects from CISCO-PROCESS-MIB
ie. cpmCPUTotal5secRev instead.
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
thank you Afroj, it works
Hi Ylvie,
Thanks for the update.
If this post answers your question, please click the "Correct Answer" button"
Afroj
can't find the "Correct Answer" button...sorry
