Nexus 5K call-home source IP address
Daniel Hunter
We are configuring a number of Nexus 5548P switches, in a test environment, and have set up call-home to deliver alerts to our local exchange, which we have working, however the source IP address for the call-home traffic is the that of the outgoing interface in the direction of the SMTP server. This will be a problem in the production environment so I am looking for an equivalent to the router call-home command 'source-interface loop 1' which doesn't seem to exist on NX-OS. Does any have a workaround for this missing functionality?
Hello Daniel,
Have you had a solution for this issue ?
Thanks.
I have a few messy work rounds using vrf or nat but no real solution yet.
