Nexus 7000 Interactive Action with TCL or Python
jaemlee
hello, Team
Does anybody know how we can trigger interactive action with EEM?
Cu hope to execute some command sets to another device with specific event.
I've tried to test with TCL/Python with CLI but interactive mode didn't support by CLI/EXEC.
    N7K_1-tcl# cli "telnet localhost"
    Cannot run interactive command with cli/exec prefix.
    N7K_1-tcl#
Is there any idea to work this scenario properly?
Or Anybody guide where is the TCL Library can use inside of N7K?
Just it looks simple, but couldn't work it easy in N7K.
Hope to get any clever idea from experts
Best Regards
Jaemi Lee
Jason Mann
Frequent Visitor
Frequent Visitor
Did you ever get this figured out?
Joe Clarke
NX-OS EEM does not support interactive commands.  However, you can send a trap from an EEM applet to another device.  If that device is an IOS[-XE] device that can intercept traps with its EEM, then you can have it execute the commands based on the reception of that trap.
If the two devices are connected via a direct link, you could momentarily bounce the port to generate a link down syslog and have the peer device react to that.
