Nexus NTP Issue
Ian Beck
I have a Nexus 5598 with a layer 3 moudule.
I have configured NTP and this is working to the peer source, via a FW.
My problem is, that I have configured Distrubute so that down stream Routers/Switches can source their NTP update from the Nexus Switches.
However when I configure the down stream devices to receive updates from the loopback address the, the association is left in .INIT. state. If I configure to use a VLAN HSRP address the ntp assocaitaion work's, ass follows
  address         ref clock       st   when   poll reach  delay  offset   disp
~x.x.x.10     .INIT.          16      -   1024     0  0.000   0.000 15937.          - loopback
~x.x.x.11     .INIT.          16      -   1024     0  0.000   0.000 15937.      - loopback
*~x.x.x.254    x.x.x..227     3    115    128   177  2.136  23.156 66.268    - HSRP
NTP debug on a down stream switch, shows the ntp message being sent with no reply to the loopback, the loopback address is pingable.
Has any one seen this sort of issue ?
Many thanks
Leo Laohoo
This is a known issue.  Search this forum for "Nexus NTP" and you'll get alot of hits.
