06-06-2012 03:16 AM
I work with cisco nexus 1000v (os image nexus-1000v-kickstart-mz.4.2.1.SV1.5.1.bin)
I have problems with syslog messages I receive on syslog server.
All messages I receive on syslog server don't have host name, which make it difficult to identify
the origin of the message.
It looks like that (on syslog server):
<190>: 2012 Jun 6 07:52:20 UTC: %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; logging level aaa 7 (SUCCESS)
<190>: 2012 Jun 6 07:52:25 UTC: %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; ip access-list qqq (SUCCESS)
<190>: 2012 Jun 6 07:52:30 UTC: %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; ip access-list qqq ; 22 permit ip any any (SUCCESS)
But on the device it looks like that:
2012 Jun 6 07:52:20 roei_nexus %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; logging level aaa 7 (SUCCESS)
2012 Jun 6 07:52:25 roei_nexus %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; ip access-list qqq (SUCCESS)
2012 Jun 6 07:52:30 roei_nexus %AAA-6-AAA_ACCOUNTING_MESSAGE: update:192.168.5.88@pts/5:admin:configure terminal ; ip access-list qqq ; 22 permit ip any any (SUCCESS)
Maybe somebody encountered such problem and know how to change message format that it will contain hostname/ip on the remote server.
Thank you
06-06-2012 11:53 AM
Do you have "hostname [hostname]" configured?
What's your current "show run" look like?
06-07-2012 12:57 AM
Yes definitely I have hostname configured,
here is my config:
!Command: show running-config
!Time: Thu Jun 7 07:48:15 2012
version 4.2(1)SV1(5.1)
feature telnet
logging level aaa 7
username admin password 5 $1$NkkczGV.$cvskA7PlYvB2S1/9pYLKt1 role network-admin
banner motd #Nexus 1000v Switch#
ip domain-lookup
ipv6 host tuf 2222::1111
ip host evgeny_desck 192.168.5.88
ip host evgeny_desck2 192.168.5.81
hostname roei_nexus
system default switchport
logging event link-status default
ip access-list Vlan2014_ingress
statistics per-entry
1 permit ip any any
2 permit icmp any any
3 permit tcp any any
4 permit udp any any
ip access-list ddd
10 permit ip any any
20 permit ip any any
30 permit ip any any
50 permit ip any any
100 permit ip any any
110 permit ip any any
120 permit ip any any
130 permit ip any any
160 permit ip any any
ip access-list evgeny_acl
10 permit icmp any any
30 permit tcp any any
40 permit udp any any
50 deny ip 2.2.2.2/32 3.3.3.3/32
51 deny ip 2.2.2.2/32 3.3.3.3/32
ip access-list lab
10 permit ip 10.0.0.0/8 any
20 deny ip 192.168.1.0/24 any
ip access-list shay
20 permit tcp any any eq www
30 permit tcp 5.5.5.0/24 any eq exec
40 permit udp 1.1.1.1/32 range isakmp rip 2.2.2.0/25 eq snmp dscp cs3
50 permit udp 1.1.1.1/32 2.2.2.2/32 eq 66
60 permit tcp any neq nntp any neq nntp
70 permit tcp any neq nntp any neq nntp syn
80 permit tcp any neq nntp any neq nntp ack
90 permit tcp any neq nntp any neq nntp rst
100 permit tcp any neq nntp any neq nntp fin
110 permit tcp any neq nntp any neq nntp dscp cs1
120 permit tcp any neq nntp any neq nntp urg
130 permit tcp any neq nntp any neq nntp psh
140 permit tcp any neq nntp any neq nntp established
150 permit tcp any any eq 8080
160 permit tcp any 88.88.88.0/26 eq 8080
ip access-list tuf
10 permit tcp any any eq www
snmp-server user admin network-admin auth md5 0xb010a509f59f94aeb07c3d08d8d035f9 priv 0xb010a509f59f94aeb07c3d08d8d035f9 localizedkey
snmp-server community snmp4u group network-operator
vrf context management
ip route 0.0.0.0/0 10.17.1.1
ip route 0.0.0.0/0 192.169.1.2 1
vlan 1
vlan 1
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
vdc roei_nexus id 1
limit-resource vlan minimum 16 maximum 2049
limit-resource monitor-session minimum 0 maximum 2
limit-resource vrf minimum 16 maximum 8192
limit-resource port-channel minimum 0 maximum 768
limit-resource u4route-mem minimum 1 maximum 1
limit-resource u6route-mem minimum 1 maximum 1
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
interface mgmt0
ip access-group evgeny_acl in
ip access-group evgeny_acl out
ip address 192.168.21.10/16
interface loopback1
interface loopback17
no ip redirects
ip address 20.20.20.22/24
ip address 20.20.22.22/24 secondary
ip address 20.20.22.23/24 secondary
interface loopback23
ip address 88.88.88.88/24
ipv6 address 2620::1b05:1401:0000:0000:0000:0005/128
interface control0
ip address 192.168.21.11/16
line console
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1.bin sup-2
ip route 0.0.0.0/0 192.168.1.2
ip route 45.45.45.0/24 10.17.1.99
ip route 50.50.50.0/30 10.100.0.77
ipv6 route 0::/0 fd80::1111
svs-domain
domain id 2
control vlan 1
packet vlan 1
svs mode L3 interface mgmt0
vsn type vsg global
tcp state-checks
vnm-policy-agent
registration-ip 0.0.0.0
shared-secret **********
log-level info
logging logfile evgeny.log 7
logging server 192.168.21.2 7
logging module 7
logging timestamp milliseconds
