No devices found
alkabeer80
I install LMS 4 and run discovery for devices it found 95 device ( managed devices)
In the following path : Inventory--Device Administration--Discovery--Launch/Summary the result is:
Discovery Status: Completed
Total Devices discovered :95
Now if to go to report--inventory--detailed device and expand " All devices" there is nothing inside it and also the same on all other locations , i run the device collector and when i press on show devices i can c the deivces.
Fadi Twal
try to reboot the server and wait for some time.
let me know if that helps.
Fadi Twal
It Works, Thanks Fadi
Hi Fadi,
I have another issue, in my organziation i have ciscoworks 2000 which has reachablitly dashboard for WAN interfaces so that if any interface fail down the helpdesk people will be notified directly.
Can i have the same feature and same dashboard in ciscoworks 4.0 ? if not how can i achive this
i have attached the reachability dashboard for ciscoworks 2000
