no matching key exchange method found. Their offer: diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
KjeldFlarup
When I try to connect to my switch I get this error
$ ssh cisco@192.168.7.203
Unable to negotiate with 192.168.7.203 port 22: no matching key exchange method found. Their offer: diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
And I just did a factory default on this box
System Description:	SG300-52 52-Port Gigabit Managed Switch
Firmware Version (Active Image):	1.4.11.5
Boot Version:	1.3.5.06
Configured it like this
configure
interface vlan 1
 ip address 192.168.7.203 255.255.255.0
 no ip address dhcp
ip default-gateway 192.168.7.1
end
config
ip ssh server
ip ssh-client server authentication
ip ssh-client source-interface  vlan 1
end
copy running-config startup-config
reload
What am I missing?
This works, but I would like to configure the switch properly
ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 -c aes256-ctr  cisco@192.168.7.203
7 Replies 7
marce1000
 - Not much you can do , available ciphers may be limited depending on model , but also firmware version (use the latest and or try again). Can be verified with :
nmap --script ssh2-enum-algos your-switch
 M.
**bleep**, even the largest switch supplier in the world cannot offer a secure switch.
22/tcp  open  ssh
| ssh2-enum-algos:
|   kex_algorithms: (2)
|   server_host_key_algorithms: (2)
|       ssh-rsa
|       ssh-dss
|   encryption_algorithms: (3)
|       aes128-ctr
|       aes192-ctr
|       aes256-ctr
|   mac_algorithms: (1)
|       hmac-sha1
|   compression_algorithms: (1)
|_      none
Neither diffie-hellman-group-exchange-sha1, diffie-hellman-group1-sha1 is considered secure. https://tools.ietf.org/id/draft-ietf-curdle-ssh-kex-sha2-09.html
And 1.4.11.5 is the latest available firmware.
 - Small business devices may have security limits (too) ,indeed.
 M.
Maybe you can try to add your linux ssh_config file in directory/etc/ssh "KexAlgorithms +diffie-hellman-group1-sha1". In fact, the underline keyword can be change depending your device answers. In my case it was +diffie-hellman-group14-sha1.
jkinnaird1
I had this problem as well - I found a good solution here !
https://www.petenetlive.com/kb/article/0001245
Very good!
taoza
Thanks a lot.
