Not able to connect to Wifi on laptop even after resetting router and network adapter
gamerboy09pc
I can access internet using same Wifi from another laptop/phone. Can't access it on only one laptop. Internet is not accessible even from hotspot created from another laptop successfully connected to the wifi.
I can connect to internet on this laptop from other Wifi like phone hotspot.
I reset my router, rebooted it multiple times. Reinstalled network adapter. Restarted laptop.
Can't ping to default gateway (request timed out)
Reset winsock and ipv4 with netsh.
ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.1.1      192.168.1.2     50
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
      169.254.0.0      255.255.0.0         On-link   169.254.185.171    281
  169.254.185.171  255.255.255.255         On-link   169.254.185.171    281
  169.254.255.255  255.255.255.255         On-link   169.254.185.171    281
      192.168.1.0    255.255.255.0         On-link       192.168.1.2    306
      192.168.1.2  255.255.255.255         On-link       192.168.1.2    306
    192.168.1.255  255.255.255.255         On-link       192.168.1.2    306
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link   169.254.185.171    281
        224.0.0.0        240.0.0.0         On-link       192.168.1.2    306
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link   169.254.185.171    281
  255.255.255.255  255.255.255.255         On-link       192.168.1.2    306
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) Wireless-AC 9560 160MHz
   Physical Address. . . . . . . . . : 14-4F-8A-BC-AA-F7
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : fd01:5ca1:ab1e:8b23:9c9e:8f4f:1154:f628(Preferred)
   Link-local IPv6 Address . . . . . : fe80::65d7:d10:7a1a:4144%6(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 26 April 2021 23:31:03
   Lease Expires . . . . . . . . . . : 27 April 2021 23:31:02
   Default Gateway . . . . . . . . . : 2606:4700:d0::a29f:c009
                                       fe80::1%6
                                       192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 554979210
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-D2-8F-40-B4-B6-86-DE-9C-2C
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   Primary WINS Server . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
balaji.bandi
Looks More issue with Device Wifi Driver, check in the device manager has latest Drivers or is the WIFI disbaled ?
check the event viewer any logs to identify the issue.
After your new Config - Try disable IPv6 and test (what is the outcome ?)
BB
balaji.bandi
BB
gamerboy09pc
I did two things just now. Disable firewall and switch off (and later) uninstall Cloudflare Warp. One of these two things or something else in the meantime solved the issue. I even turned on firewall again and it still works. I thing Cloudflare Warp updated yesterday, and it caused the issue.
Sure as mentioned its something to do with Pc device, glad all went well and working....we mark as this resolved.
BB
yes thanks.
It is a issue because of cloudflare warp as it can't establish the connection. Without it the internet works fine. Seems it has been blocked by my ISP (Airtel broadband).
