Not able to register a Simple script to capture high cpu usage
rbunal
When attempting to register the TCL script on my ASR 9K I get an error:
event manager policy cpu_80.tcl username admin persist-time 3600 type user
!!% Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy cpu_80.tcl
::cisco::eem::event_register_wdsysmon sub1 cpu_tot op ge val 80
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
cli_exec $cli1(fd) "term len 0"
cli_exec $cli1(fd) "show processes cpu location 0/RSP0/CPU0 | file append disk0a:/usr/cpucap.txt"
cli_exec $cli1(fd) "show processor cpu location 0/RSP1/CPU0 | file append disk0a:/usr/cpucap.txt"
cli_exec $cli1(fd) "show processor cpu location 0/0/CPU0 | file append disk0a:/usr/cpucap.txt"
cli_exec $cli1(fd) "show processor cpu location 0/1/CPU0 | file append disk0a:/usr/cpucap.txt"
catch {cli_close $cli(fd) $cli(tty_id)}
I'm able to register and run it as a manual script fine "::cisco::eem::event_register_none"
Thanks for your help.
Joe Clarke
You're missing the "period" keyword in your event spec line.  You need to specify a polling period for wdsysmon (e.g., period 60).
Thanks Joe.  I added the period 60, but it's still failing on registration.
::cisco::eem::event_register_wdsysmon sub1 cpu_tot op ge val 80 period 60
Depending on your version of code, you may need:
::cisco::eem::event_register_wdsysmon timewin 60 sub1 cpu_tot op ge val 80
