NTP authentication on 3750
phil_carter
Trying to apply NTP authentication to 3750 switches (layer-2 WS-C3750-24P switches) but they don't wont to work. Applying the same config to any router or 4500/6500 chassis, and NTP authenticates straight away. NTP without authentication works fine on 3750s as well...
ntp authentication-key 1 md5 <key>
ntp authenticate
ntp trusted-key 1
ntp server 10.200.11.200 key 1
Is there additional config required for 3750s? This is across different IOS versions, so doesn't look like a bug...
Phil
phil_carter
ah - you have to be careful what order you paste commands in as it removes trusted-key 1 sometimes...
