NTP Authentication
moeezaftab
Hope you all are good. I got the feed from NTP server on my 6500 switch. After that I want that other devices on my network will get feed from my switch after authentication. But other devices on network is getting feed without authentication.
6500 Switch Config:
ntp logging
ntp authentication-key 1 md5 xxxxxxxx
ntp authenticate
ntp trusted-key 1
ntp source Vlan264
ntp update-calendar
ntp master
ntp server 82.200.209.236
Router who is getting feed from 6500:
ntp authentication-key 1 md5  xxxxxxxx 7
ntp authenticate
ntp source GigabitEthernet0/0.264
ntp master
ntp server 1.1.1.1 [This select 6500 switch for synchronization, but for authentication it should be [ntp server 1.1.1.1 key 1]. But it won't work]
Please guide me if I am making any mistake. The output of router is given below.
AT-INT-RTR-2951-2#sho ntp associations
address ref clock st when poll reach delay offset disp
~127.127.1.1 .LOCL. 7 9 16 377 0.000 0.000 0.252
*~1.1.1.1        2.2.2.2  5 341 512 377 0.655 -7.872 7.434
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
0 Replies 0
