NTP Problem
robertgile1
Community Member
I am having a problem with NTP. My network setup looks like this:
2821 Router <-> ASA 5510 <-> W2k3 DC
I have the router pulling time from a NIST NTP server. I want the W2k3 DC to pull from the router.
I have opened a hole in the firewall to allow the router to pass UDP 123 to the outside interface on the ASA. I have setup a NAT translation to translate to the W2k3 DC's private IP.
This is what I am getting from the debug on the router:
Aug 4 20:10:06.369: NTP: packet from x.x.x.x failed validity tests 0E
Aug 4 20:10:06.369: Bogus Packet received
Aug 4 20:10:06.369: Protocol unsynchronized
Aug 4 20:10:06.369: Peer/Server delay/dispersion boundary check failed
This is the router config:
ntp clock-period 17180270
ntp master
ntp server 69.25.96.13
For the W2K3 DC, I have the router IP in the following reg key:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Parameters]
"NtpServer"="x.x.x.x"
"Type"="NTP"
I can not find that "failed validity tests 0E" specifically anywhere.
Any suggestions? Thank you in advance.
7 Replies 7
Joe Clarke
This error indicates bogus originating information in a packet received by the router. What is the output of show ntp assoc and show ntp stat on this router?
I was successfully able to sync a Windows 2003 server with a 7206 running 12.4(15)T5 with the following config:
ntp clock-period 17179698
ntp master 3
ntp server 10.1.1.1
My router is synced to a stratum 2 clock on 10.1.1.1.
My Windows registry looks like:
NtpServer=20.1.1.1,0x1
Type=NTP
I have the following:
router#show ntp assoc
address ref clock st when poll reach delay offset disp
~127.127.7.1 127.127.7.1 7 60 64 377 0.0 0.00 0.0
*~69.25.96.13 .ACTS. 1 704 1024 377 17.4 1.09 1.9
I have no idea where the 127.127.7.1 address came from.
router#sho ntp stat
Clock is synchronized, stratum 2, reference is 69.25.96.13
nominal freq is 250.0000 Hz, actual freq is 249.9944 Hz, precision is 2**18
reference time is CC420C1D.54D4EC22 (16:15:41.331 PST Mon Aug 4 2008)
clock offset is 1.0932 msec, root delay is 17.43 msec
root dispersion is 3.02 msec, peer dispersion is 1.94 msec
127.127.7.1 is the router itself. Try setting its stratum to 2:
ntp master 2
Then, enable debug ntp packet, and try to sync from the Windows 2003 machine again. what output do you get?
Here is my output:
Aug 5 14:33:42.583: NTP: rcv packet from [non-NATed DC IP] to [router's internal IP] on GigabitEthernet0/0:
Aug 5 14:33:42.583: leap 0, mode 3, version 3, stratum 1, ppoll 32768
Aug 5 14:33:42.583: rtdel 0000 (0.000), rtdsp A0400 (10015.625), refid 4C4F434C (76.79.67.76)
Aug 5 14:33:42.583: ref CC42E296.E0000000 (07:30:46.874 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: org 00000000.00000000 (17:00:00.000 PST Wed Dec 31 1899)
Aug 5 14:33:42.583: rec 00000000.00000000 (17:00:00.000 PST Wed Dec 31 1899)
Aug 5 14:33:42.583: xmt CC42E296.E0000000 (07:30:46.874 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: inp CC42E346.956EFFCD (07:33:42.583 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: NTP: stateless xmit packet to [non-NATed DC IP]:
Aug 5 14:33:42.583: leap 0, mode 4, version 3, stratum 2, ppoll 32768
Aug 5 14:33:42.583: rtdel 0574 (21.301), rtdsp 020E (8.026), refid 4519600D (69.25.96.13)
Aug 5 14:33:42.583: ref CC42E2CA.9500482E (07:31:38.582 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: org CC42E296.E0000000 (07:30:46.874 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: rec CC42E346.956EFFCD (07:33:42.583 PST Tue Aug 5 2008)
Aug 5 14:33:42.583: xmt CC42E346.9594C0D7 (07:33:42.584 PST Tue Aug 5 2008)
Aug 5 14:33:42.679: NTP: rcv packet from [NATed DC IP] to [router's internal IP] on GigabitEthernet0/0:
Aug 5 14:33:42.679: leap 0, mode 1, version 3, stratum 1, ppoll 32768
Aug 5 14:33:42.679: rtdel 0000 (0.000), rtdsp A0400 (10015.625), refid 4C4F434C (76.79.67.76)
Aug 5 14:33:42.679: ref CC42E296.DFD70A3D (07:30:46.874 PST Tue Aug 5 2008)
Aug 5 14:33:42.679: org 00000000.00000000 (17:00:00.000 PST Wed Dec 31 1899)
Aug 5 14:33:42.679: rec 00000000.00000000 (17:00:00.000 PST Wed Dec 31 1899)
Aug 5 14:33:42.679: xmt CC42E296.FC000000 (07:30:46.984 PST Tue Aug 5 2008)
Aug 5 14:33:42.679: inp CC42E346.AE168159 (07:33:42.680 PST Tue Aug 5 2008)
Aug 5 14:33:49.563: NTP: xmit packet to [NATed DC IP]:
Aug 5 14:33:49.563: leap 0, mode 2, version 3, stratum 2, ppoll 64
Aug 5 14:33:49.563: rtdel 0574 (21.301), rtdsp 020E (8.026), refid 4519600D (69.25.96.13)
Aug 5 14:33:49.563: ref CC42E2CA.9500482E (07:31:38.582 PST Tue Aug 5 2008)
Aug 5 14:33:49.563: org CC42E296.FC000000 (07:30:46.984 PST Tue Aug 5 2008)
Aug 5 14:33:49.563: rec CC42E346.AE168159 (07:33:42.680 PST Tue Aug 5 2008)
Aug 5 14:33:49.563: xmt CC42E34D.9053227F (07:33:49.563 PST Tue Aug 5 2008)
I'm thinking the problem is the ASA in between the DC and the router. I have an access rule allowing UDP from the router to the ASA external IP as well as a NAT translation for NTP to the inside DC IP.
Are you doing static NAT on the ASA for the DC?
Yes.
The router is replying to both sync requests. Can you sniff the traffic to make sure the Windows server is seeing the reply?
