NX-OS - How include or exclude an OID from the SNMP view entry???
valoreconomico
Hi, I'm working with Nexus 7010 - System version: 5.1(3).
For example, in the 7200 we can include or exclude an OID from the SNMP view entry using the command #snmp-server view.
How can we include or exclude an OID from the SNMP view entry in the Nexus 7010???
Thanks.
Gaganjeet Chug
Level 4
Level 4
In nx-os they have not included the snmp-server view command as of yet.  What they did include was the rbac feature that can be used to do  something similar.  Unfortunately they have had some issues with this  and there is a bug that is outstanding that causes this feature to not  work in conjunction with snmp and vlans/vrfs:
CSCtc86349    SNMP does not apply interface RBAC at all
So at this time there is not a way to block the OID using a view  or rbac in nx-os.
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
Gaganjeet
