OID for RxPause
I have a cisco WS-C4948E and i found the increasing of RxPause from the
#show flowcontrol interface tenGigabitEthernet 1/50 command then i want to monitor the RxPause and i try to find the OID but i'm not.
Anyone can find the OID?.
ccube
Level 4
Level 4
If the device supports the Etherlike-Mib, dot3InPauseFrames (rxpause) and dot3OutPauseFrames (txpause) would be the likely oids....
http://www.oidview.com/mibs/0/EtherLike-MIB.html
ccube
Level 4
Level 4
