02-12-2016 03:42 AM
this is my first post and I can not explain it right , my English is not very good.
I want to monitor the power supply and fans in an ASR- 920-12CZ -A using SNMP OID 's but I have found are not compatible with this model.
Can anyone help me with this issue? Does anyone know which OID should I use to known if the source / fan are OK ?
Thank you
OID fan: 1.3.6.1.4.1.9.9.13.1.4.1.3 (not compatible with cisco ASR-920-12CZ-A)
OID Power Supply: 1.3.6.1.4.1.9.9.13.1.5.1.3 (not compatible with cisco ASR-920-12CZ-A)
Solved! Go to Solution.
02-15-2016 12:50 AM
Yep, your OIDs are from CISCO-ENVMON-MIB and it isn't supported by Cisco ASR 920. You can check mib compability here - http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=4407&PlatformSel=247&fsSel=300
And I think you should use this MIB - http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-ENTITY-FRU-CONTROL-MIB
It looks like it has info about power supplies and fans state.
02-15-2016 12:50 AM
02-17-2016 03:37 AM
Hi Alexey,
thanks for your answer. For power supplies I used the oid 1.3.6.1.4.1.9.9.117.1.1.2.1.2; cefcFRUPowerOperStatus;mib CISCO-ENTITY-FRU-CONTROL-MIB.
for now , I have not found the OID for the status of the fans . I'll keep looking.
thanks
10-16-2017 07:55 AM
Hi , for me this oid
OID |
.1.3.6.1.4.1.9.9.117.1.4.1 |
Gave me results, you can try!
04-28-2019 12:27 PM
Hi Sergio ,
I used the OID 1.3.6.1.4.1.9.9.117.1.1.2.1.2 for power supply and get the Power status .
Please help to find out the OID for Fan status on ASR920 platform .
