OIDs for IPv6 statistics
ROMAN TOMASEK
I know that MIBs for IPv6 exist: IP-MIB and IP-Forward-MIB. But I didn't find the oids for following statistics:  IPv6 ifInPackets, IPv6 ifInUcastPkts, IPv6 IfOutUcastPkts and so on. Does somebody Know the oids for these IPv6 statistics?
Thank you
Roman
begomez
Hi Roman,
As long as your device and version have support for the IP-MIB you would most likely be after OID's in the ipIfStatsTable. (In case you are not aware, you can check for device/version support by checking out the Cisco IOS MIB Locator here: http://www.cisco.com/go/mibs .
From my understanding of your issue, you would likely be after the following, depending if you are after the 32-bit or 64-bit counters:
ipIfStatsInOctets - 1.3.6.1.2.1.4.31.3.1.5
ipIfStatsHCInOctets - 1.3.6.1.2.1.4.31.3.1.6
ipIfStatsOutOctets - 1.3.6.1.2.1.4.31.3.1.32
ipIfStatsHCOutOctets - 1.3.6.1.2.1.4.31.3.1.33
The two indexes for the ipIfStatsTable (1.3.6.1.2.1.4.31.3) are:
(i) .1 - ipIfStatsIPVersion (whether the interface statistic applies to either IPv4 or IPv6).
(ii) .2 - ipIfStatsIfIndex (which corresponds to the ifIndex).
If you can let me know if I understood your requirement correctly, or if not, if you can clarify that would be great.
Ben
