02-08-2020 05:02 PM
Alright,
I'm not doing anything major to say the least, just testing outta website of my server for tests sake only. So I simply turn on the application and it runs off of port 80 then turn Apache then my SQL on and can from either a local address or the external. I test it internally, everything works out.
So now to allow external access, I go to port forward the router (using a different port this time such as 80-8080, etc) whatever may not be used at the moment or in the near future. Enabled. Double checked my range. Checked for correct computer address (and it is a static address). Go to access the site and nothing also i gave the IP to my friend no connection. Unable to connect.
I am using no IP for any dynamic changes so no worries there.
This is the program, " The uniform server"
What I am thinking is that the modem is causing some sort of trouble even though it isn't supposed to be. Regular router.
Idea's? "Well? or any suggestions would help.
I'm sure it's something simple. But my reach to do things simply is not so.
PS: I disabled my antivirus/fire wall to allow the connection with ports 7171/7172 on game play it works, SITE PORT 80 NOT WORKING!.
02-08-2020 08:45 PM
Sorry, I may be not able to get or follow what you try to achieve here.
Please provide the below information to understand the problem clearly.
1. what is this device you trying?
2. what was the version of code is running.
3. is the port access you able to to work from the internet to Lan inside, or inside LAN only?
4. if this is your PC, then windows 10 onwards by default come with FW - so we need to disable and test it, or allow them to work, - Question here, from where you try to access this port 80 or 8080? what is your source IP address, what is your web server IP address?
02-10-2020 04:45 PM - edited 02-10-2020 04:48 PM
@balaji.bandi1. if you mean with the device so I'm using pc or if you mean with the router I'm using
- HG630 V2 Home Gateway
.2. what exactly you mean with code if you mean with uniserver application I'm using uniserver 13.3.2.3. the port works from Lan to the internet because I use it as host.4. excuse me I don't understand what exactly this meaning " 10 onwards by default come with FW - " .5. i need to access this port to work from router and need to open my site with this port to make people able to connect with my site and my source ip is 192.168.1.2 and puplic ip is 197.34.38.175 and web server is http://otmadness.sytes.net/6. Some another ports is working like 7171 and 7172 but 80 not working .Thanks for your reply i hope you help me please
02-11-2020 12:53 AM
I may be wrong here
HG630 V2 Home Gateway - is this cisco product never heard - i just asked google it come up as Huawei ? is this correct.
Then you are in the wrong forum and wrong vendor here (if not please excuse here, cisco has many products hard to track all).
