02-26-2007 11:16 AM
Is the following error of any concern, for LMS 2.2?
Can't open perl script "/opt/CSCOpx/bin/dbstop.pl": No such file or directory
I can't find this file anywhere.
02-27-2007 11:36 AM
mcp is part of Core, and not used by LMS. It is part of VMS. If you don't have VMS, then you don't need to worry about this.
Symbolic linking is not on our roadmap. We do, however, support moving a lot of the information (like configs and SWIM images) to arbitrary locations on the file system.
02-27-2007 11:21 AM
Hah, I don't know how I missed the diff between /product/CSCO/CSCOpx/etc/install.profile and install.cshrc with the other box when I first looked at them.
We're speculating that the LMS patches were installed either in single-user mode or there were more kernel panics than the one during the DST patch, so /var/sadm (on SAN) wasn't mounted when CS22-SP3 went int, which caused the pkgadd to blow away the /var/adm/CSCOpx symlink.
A question, must the LMS 2.2 DST patch be reinstalled if any other patch is applied after it?
Thanks for all your help.
02-27-2007 11:33 AM
No. The DST patch is unique, and subsequent patches will not overwrite it (or they will explicitly say re-application is required).
02-27-2007 12:31 PM
Do you think of these patches need to be re-applied?
cw-common-services-2.2-sp3-sol-K9.tar.gz
cwcs2.2-sol-CSCsc30604-K9.tar.gz
cwcs2.2-sol-CSCse127781-k9.tar
cwcs2.2-sol-CSCsg58592-K9.tar.gz
The dbsrv processes are still not shutting down with dmgtd stop after I modified the three aforementioned files:
/product/CSCO/CSCOpx/etc/install.cshrc
/etc/init.d/dmgtd
tail daemons.log
Cache size adjusted to 54736K
Performance warning: no unique index or primary key for table "CampusUserGroupAs
sociationTable"
Stopping database engine aniEng
There are still active connections. Stop anyway? (Y/N) 2007-02-27 15:29:39 RV: T
IB/Rendezvous Error Not Handled by Process:
{ADV_CLASS="WARN" ADV_SOURCE="SYSTEM" ADV_NAME="RVD.DISCONNECTED"}
TIB/Rendezvous daemon
Copyright 1994-2002 by TIBCO Software Inc.
All rights reserved.
Version 7.0.21
Stopping database engine cmfEng
There are still active connections. Stop anyway? (Y/N) Stopping database eng
ine rmeEng
ine SqlCoreDBServer
Received signal (15)
1098757The SQL execution was successful during 1 try[Tue Feb 27 15:30:50 2007] [
diskWatcher] Exiting on signal :15
WARNING: dmgtd exiting now: (thread:1 sig:15)
INFO >>>>>>>>>>>>>>>>>>>>>>>>>>>>> REACTOR thread (tid=1) exited; rc=1.
02-27-2007 12:49 PM
The DST patch may need to be reapplied. It doesn't seem to have completed successfully.
