ospf neighbor not working
daniel4579329
hi
im learning for the ccna and im working on ospf and i cant make R2 to learn routes via ospf on port fa1/0 no i tried to do this via the network command and also via the command under the port can someone look at the packet tracer file and tell me what i dont see
thanks for the help (:
Farhan64
YOUR FA1/0 IP ADDRESS IS NOT PROPER
Router#sh ip ospf neighbor
THIS IS WHAT FA1/0 IS SHOWING BEFORE CORRECTING THE IP ADDRESS
Router#sh ip interface f1/0
FastEthernet1/0 is up, line protocol is up (connected)
Internet address is 200.20.0.1/8
Broadcast address is 255.255.255.255
AND YOUR NEIGHBOUR TABLE
Neighbor ID Pri State Dead Time Address Interface
10.12.0.1 1 FULL/BDR 00:00:36 100.0.0.1 FastEthernet0/0
Router#sh ip protocols
Routing Protocol is "ospf 1"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Router ID 200.20.0.1
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
Maximum path: 4
Routing for Networks:
100.0.0.0 0.255.255.255 area 0
200.20.0.0 0.0.0.255 area 0
11.0.0.0 0.255.255.255 area 0
Routing Information Sources:
Gateway Distance Last Update
10.12.0.1 110 00:01:16
200.20.0.1 110 00:01:16
Distance: (default is 110)
YOUR IP WAS 200.20.0.1/8 and
AND YOUR NEIGHBOR MASK IS  /24
OSPF routers cannot form neighbor relationship due to a mismatch in Hello or Dead parameters. Following parameters in Hello packets should match between neighboring routers:
  • Hello and Dead intervals
  • Area ID
  • Authentication type and password
  • Stub Area flag
  • Subnet ID and Subnet mask
SUBNET MASK WAS WRONG.. CORRECT IT
Router(config-if)#ip address 200.20.0.1 255.255.255.0
Internet address is 200.20.0.1/24
here is your neighbour table
200.20.0.3 1 FULL/BDR 00:00:35 200.20.0.3 FastEthernet1/0
200.20.0.2 1 2WAY/DROTHER 00:00:35 200.20.0.2 FastEthernet1/0
200.20.0.4 1 FULL/DR 00:00:35 200.20.0.4 FastEthernet1/0
10.12.0.1 1 FULL/BDR 00:00:35 100.0.0.1 FastEthernet0/0
Martin L
as mentioned above, you have wrong /8 mask but others have /24.  To exchange routes, OSPF and other protocols must be on the same network/link.
change mask to 255.255.255.0 on R2's interface FastEthernet1/0 with ip address 200.20.0.1
Regards, ML
**Please Rate All Helpful Responses **
