Packet Tracer – Create a Simple Network Using Packet Tracer (errors)
netacad_user
Community Member
I'm new to Packet Tracer and trying to set up a simple network (Packet Tracer Create a Simple Network Using Packet Tracer). I got the following messages on my command prompts:
Packet Tracer PC :
  Packet Tracer PC Command Line 1.0
  C:\>ipconfig /release
  IP Address......................: 0.0.0.0
  Subnet Mask.....................: 0.0.0.0
  Default Gateway.................: 0.0.0.0
  DNS Server......................: 0.0.0.0
  C:\>ipconfig /renew
  DHCP request failed.
  C:\>
Packet Tracer Laptop:
  C:\>ipconfig /renew
  IP Address......................: 192.168.0.101
  Subnet Mask.....................: 255.255.255.0
  Default Gateway.................: 192.168.0.1
  DNS Server......................: 208.67.220.220
  C:\>ping Cisco.com
  Ping request could not find host cisco.com. Please check the name and try again.
  C:\>
My file is attached to this post. Thanks for your help in advance.
Martin L
Your link between Router and Cable modem is connected to wrong port on Router.  If you move mouse pointer over router, you see Internet port is not connected, it does not have IP from DHCP.  Delete link and reconnect using auto link Or manual connection to Internet port.   Make sure you use Internet port towards Modem.  After that Router should get IP from DHCP server and ping as well website cisco com will work.
C:\>ping Cisco.com
Pinging 208.67.220.220 with 32 bytes of data:
Reply from 208.67.220.220: bytes=32 time=16ms TTL=127
Reply from 208.67.220.220: bytes=32 time=1ms TTL=127
Reply from 208.67.220.220: bytes=32 time=2ms TTL=127
Regards, ML
**Please Rate All Helpful Responses **
Martin L
C:\>ping Cisco.com
Regards, ML
