Packet tracer - Home network
jacobduduc
I have a packet tracer assignment to set up a smart home network. But on the label and explanation it uses ethernet to connect fan and light which doesn't work in packet tracer anymore.
Google link to my attempt of it https://drive.google.com/file/d/10p1-NG5gLXh82r5u5FmOrTJ08M9G3g1_/view?usp=sharing
Here is the instruction for the assessment for context:
Set the server up with the IP address 192.168.1.1 /24. Configure this server as a DHCP server for the 192.168.1.0 /24 subnet. Use DHCP on the PC, fan and smart lamp to provide them with IP addresses. Configure the server to be an IoT server.
Register the PC, the fan and the smart lamp with the IoT server using the username ‘admin’ and the password ‘password’.
Using the PC, demonstrate that you can control the IoT fan and the IoT smart lamp. Set the lamp to full brightness and the fan at its highest speed.
Take a screenshot of your network configuration which shows the lamp operating at full brightness and the fan operating at high speed.
**Also please don't just do the assessment for me, just give me some help or resources to do the assessment**
the link to the file is not valid (anymore)...
