Partition Problems on CiscoWorks
cory-gray
I have a server with a 10GB "C" partition and a 100 GB "D" partition. I have accidentally installed the WHOLE Ciscworks LMS/RWAN bundle on the "C" partition. Is there a procedure to get everything over to the other partition without breaking anything? Thanks.
jimsnow
Community Member
Unsure about moving CiscoWorks, but that would work for me if someone can respond to that. I'm in the same situation.
If your CW is installed on a Windows 2000/XP box (not server), you can use Partition Magic to increase the size of your primary partition and resize the "d" partition. I'm on a server, so that isn't an option for me....
Hope this helps.
