12-31-2004 07:05 AM
I am desperate, Can somebody help me figure out why in Cisco Works Resource Manager when I look at the archive some routers/switchs have names and others only display IP addresses. Most everything is in DNS. I cannot figure it out. Is it an SNMP problem? Topology manager shows all the names but not Resource Manager. I have attached a drawing of what I am talking about. Thanks for any help.
Justin
01-03-2005 11:20 AM
It could be device syncronization from CM to RME. I have syncronization turned of from CM to RME manually adding devices to RME.
01-27-2005 03:29 PM
You could make sure that your switces are on a VTP domain..... that's probably what I would be looking at.
01-28-2005 07:08 AM
Actually I found it under discover there is a reverse DNS lookup option. That fixed it.
Thanks for the help
