PAT DOES NOT WORK
7 Replies 7
luis_cordova
Hi @andrzejsewerynwojcik
Try this:
interface GigabitEthernet0/0
no ip nat inside
interface GigabitEthernet0/0.10
ip nat inside
interface GigabitEthernet0/0.20
ip nat inside
interface GigabitEthernet0/0.30
ip nat inside
Passwords Line console :
login manager
pass CR0UTER@
privli
login manager
C@mbridge2020.
for some reasons it only increments misses
Delete this line: ip nat inside source list Deny_Manchester interface GigabitEthernet0/1 overload
Try this:
no ip nat inside source list Deny_Manchester interface GigabitEthernet0/1 overload
thats not really what i want to do as manchester site is not allowed to access the isp thats why i need this ACL. It allows everything aparat from manchester i tried to delete this before and create separate acl for testing but still the same issue
The line that I indicate is the one that is related to a NAT, but not the one that associates the ACL with the output interface.
The ACL you have created is being applied with this line:
ip address 172.16.10.1 255.255.255.252
ip access-group Deny-Manchester out
ip nat outside
I tried removing it still the same issue looks like ACL is matching the traffic but there is no translation occuring. I attached my packet tracer file
