Path Analysis not working
albatli1977
   I have server1 as primary server (LMS_3.2, CS_3.3 and RME) with AAA  Mode Setup ASC integration , second server is LMS3.2 with Campus manager 5.2.0 with AAA  Mode Setup:             TACACS+,
when I click Path Analysis URL on LMS portal from primary, the below message is appeared:
Critical Error
Your session has either timed out or you are not authorized to access  this page.
5 Replies 5
Joe Clarke
Path Analysis no longer exists in LMS 3.2.  How is it you have a link on the portal?  Is this an upgrade from a previous version of LMS?
Yes, It's upgraded from 2.5.1--2.6--3.1--3.2.
Then whatever is still showing the Path Analysis link in the portal should be deleted and recreated.  As I said, this component is no longer part of LMS.
How I can delete this link?
I don't know.  I don't know what you're seeing.  Post a screenshot of how your portal looks.
