PBR - adding a route map to an interface
RAJ VIRDI
Community Member
Hello.
I cannot add a route-map to an interface on a C3750 stack
I have copied the switch details below
#sho ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01280000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE3, RELEASE SOFTWARE (fc1)
Pleidelsheim_V1B_Core uptime is 16 hours, 43 minutes
System restarted at 22:01:48 CET Wed Mar 3 2010
System image file is "flash:/c3750-ipservices-mz.122-35.SE5.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision P0) with 118784K/12280K bytes of memory.
Processor board ID CAT1130ZK5F
Last reset from power-on
9 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1D:46:8C:22:80
Motherboard assembly number     : 73-7058-14
Power supply part number        : 341-0045-01
Motherboard serial number       : CAT113059LV
Power supply serial number      : PHI1114L1PJ
Model revision number           : P0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-E
System serial number            : CAT1130ZK5F
Top Assembly Part Number        : 800-22348-07
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COM7700ARA
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3750G-24TS     12.2(35)SE5             C3750-IPSERVICES-M
     2   28     WS-C3750G-24TS     12.2(35)SE5             C3750-IPSERVICES-M
Switch 02
Switch Uptime                   : 16 hours, 43 minutes
Base ethernet MAC Address       : 00:21:A1:2E:78:00
Motherboard assembly number     : 73-7058-15
Motherboard serial number       : FDO121903D2
Power supply serial number      : LIT121603VV
Model revision number           : Q0
System serial number            : CAT1105RGN2
Top assembly part number        : 800-22348-08
Top assembly revision number    : A0
Version ID                      : V08
CLEI Code Number                : COMUJ10ARA
Configuration register is 0xF
#sho sdm prefer
The current template is "desktop routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  3K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    11K
    number of directly-connected IPv4 hosts:        3K
    number of indirect IPv4 routes:                 8K
  number of IPv4 policy based routing aces:         0.5K
  number of IPv4/MAC qos aces:                      0.5K
  number of IPv4/MAC security aces:                 1K
When I try to add the route map
interface Vlanx
ip policy route-map xx
%PLATFORM_PBR-3-UNSUPPORTED_RMAP: Route-map xx not supported for Policy-Based Routing
Can anyone see what could be wrong?
RAJ VIRDI
Community Member
Okay, just realised the route-map is not valid.
The settings are okay.
access-list 160 remark WIRELESS GUEST PBR FWD TRAFFIC
access-list 160 permit tcp 172.16.168.128 0.0.0.63 any
access-list 160 permit udp 172.16.168.128 0.0.0.63 any
access-list 160 permit ip 172.16.168.128 0.0.0.63 any
access-list 160 permit icmp 172.16.168.128 0.0.0.63 any
route-map GUEST_VLAN-to-WEB permit 20
description FWD REMAINING GUEST TRAFFIC TO PROXY
match ip address 160
set interface Null0
Doesn't like the set interface Null0
How else could I setup a black hole
