PC bandwidth monitoring
tyagivijay
Is their any software through which we can monitor the Internet Bandwidth of the Individual PC in the LAN??
Thanks in advance
Vijay
steve.busby
Level 5
Level 5
Are you actually wanting to monitor on your edge-switch/router how much of your internet bandwidth each PC is using? You can use Netflow.
Or would you like to monitor the bandwidth of each switchport? Try something like MRTG or Cricket.
