Perl Scripting Toolkit
nikos_skalis
Frequent Visitor
Frequent Visitor
Hello All,
I am trying to use the Perl Scripting Toolkit available from Cisco :
http://www.cisco.com/cisco/software/release.html?mdfid=282414851&flowid=2137&softwareid=281035856&release=4.2.1&relind=AVAILABLE&rellifecycle=&reltype=latest
And the documentation: http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r4.1/xml/programming/guide/xl41petk.html
The purpose is to use the tar file with all the XML Schemas implemented in 4.2.1 on ASR9k:
http://www.cisco.com/cisco/software/release.html?mdfid=282414851&flowid=2137&softwareid=281024900&release=4.2.1&relind=AVAILABLE&rellifecycle=&reltype=latest
But, when I am trying to run the example scripts, I am getting :
perl show_ip_interfaces.pl -host <hostname>-pe2  -user <username> -interactive
Password:
Error: Failed to enter XML mode.
Does anyone else has encountered this before ? How can I bypass this ?
Many Thanks.
Kind Regards,
Nikos
Joe Clarke
I've not used this toolkit, but I believe it uses the same XML agent that NETCONF uses.  You should make sure you have the following configured:
netconf agent tty
Thank you Joseph for the feedback. I think I am missing the "Cisco IOS XR Manageability Package" PIE. I'll update you shortly.
