Phantom port-channel?
yjdabear
A new port-channel shows up in "show etherchannel summary" and is visible to SNMP, but is not found in either running- or startup config. None of the physical ports in the PO has been configured either. What could cause this to happen?
sh etherc summ
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
Number of channel-groups in use: 3
Number of aggregators: 3
Group Port-channel Protocol Ports
27 Po27(SU) - Gi7/1(P) Gi7/2(P) Gi7/3(P) Gi7/4(P)
Gi7/5(P) Gi7/6(P)
lgijssel
Level 9
Level 9
Could be a remainder of someone else's experiments. It should do no harm.
Try to reload the switch and see what happens.
Leo
Looks like it's a symptom of inserting a six-port firewall module into a cat6k. Three out of four cat6k's have this port-channel appear automagically after receiving the module, unconfigured but powered.
#sh mod
Mod Ports Card Type Model Serial No.
9 6 Firewall Module WS-SVC-FWM-1 SAXXXXXXXXX
Mod MAC addresses Hw Fw Sw Status
1 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 4.2 7.1(1) 12.X(XX)XX Ok
5 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 5.3 6.3(1) 8.3(0.111)TF Ok
9 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 4.0 7.2(1) 2.3(3) Ok
The only cat6k that doesn't show the port channel shows different Sw and Status.
#sh mod
1 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 4.1 7.1(1) 12.X(XX)XX Ok
3 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 1.1 7.2(1) 8.3(0.111)TF Ok
9 XXXXXXXXXXXXXX to XXXXXXXXXXXXXX 4.0 7.2(1) 8.3(0.111)TF PwrDown
