10-17-2013 07:43 PM
Prime Infrastructure User Guide p48 of 342 sais you set up Data Sources for Assurance at menu:
Administration>System Settings>Data Sources
But there is no Data Sources under System Settings. Does anybody know where that menu item really is?
Solved! Go to Solution.
10-17-2013 10:54 PM
Hi ,
You need to switch to Classic Theme then you will be able to navigate to the DATA SOURCES.
Check the attached Image.
Thanks-
Afroz
[Do rate the useful post]
10-17-2013 10:54 PM
