PI 2.0 to 2.1 Upgrade Fail
howlingthunder
Upgrade failed. Output states:
ERROR: The last upgrade operation was unsuccessful. See dbadmin_StdOut.log for details. To recover, reinstall the server and restore the saved backup data.
% Pre-install step failed. Please check the logs for more details.
I cannot find this log anywhere. I cannot reinstall as it gives me the same error. No documents reference this file or log directory on the PI VM. Any help? Anyone seen this before?
AFROJ AHMAD
Hi ,
was HA configured before on PI 2.0 ?
If yes remove the HA config from Both primary and secondary (ncs ha remove )  then try the upgrade.
I also suspect that something wrong can happen  during file transfer from ftp server .
place the upgrade file locally on the NCS server and then try the upgrade .
You can place the file under /localdisk/defaultRepo/ .
You need to login as root first then you will be able place the file into this directory below .
PI20-1/admin#
PI20-1/admin# root
Enter root password :
Starting root bash shell ...
ade #
ade #
ade # cd /
ade # cd /localdisk/defaultRepo/
ade #
After that , you can transfer the file from your ftp server to your NCS server.
Now,  you can perform the upgrade locally using console
application upgrade PI-Upgrade-2.x.x.x.x.x.x.gz defaultRepo
and lastly , the file it is pointing to ,it bydeafault location is :/opt/CSCOlumos/logs/
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks Afroz - that was actually quite helpful
No HA  - single server setup
Used vi to read through the log (thanks for the path and tip on root mode) and really no clue as to why it is failing.
I used the Quick Start Guide for 2.1 and did the local repo on the server. So, no network transfer of file for upgrade.
Each time I try again to perform the upgrade I get the error above. No sure what else to do except build a new server and hope I can migrate the database. I don't want to do that.
share the log file
Thanks-
