PI 2.1 questions
omer shtivi
I got some questions regarding PI 2.1
Can I search in all devices configuration to see if specifc command exist?
When I'm using discovery, my devices got 100% CPU, and under show proccess cpu I see that the SNMP proccess is taking all the cpu. is it normal? the switches are 3750X running version 15.2 and Nexus 5K running 6.0.2
Can I upload a specific MIBs?
Best regards,
Omer Shtivi
Does this table says that 15.2 version is supported?
Yes  ,15.2 should be supported as per the table.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Omer,
AFASIk, Compliance check feature is still missing in PI 2.1.
For CPU , better you look at  the logs and try to find out the MIB causing issue.
when the CPU is high , collect the  output of  :: show stack<PID of SNMP Engine>
with this you can go to TAC to find out the issue.
Yes , you can upload the MIBS, check the below link for more information:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/1-2/user/guide/prime_infra_ug/create_temp_mon.html#pgfId-1066507
Thanks-
Afroz
Thank you for your response.
Device TypeSYSOIDSS/W VersionSoftware
Cisco Catalyst 3750E-24TD-E,S SwitchOID:1.3.6.1.4.1.9.1.789>=12.2IOS
Cisco Catalyst 3750E-48TD-E,S SwitchOID:1.3.6.1.4.1.9.1.790>=12.2IOS
Cisco Catalyst 3750E-48PD-E,S SwitchOID:1.3.6.1.4.1.9.1.791>=12.2IOS
Cisco Catalyst 3750E-24PD-E,S SwitchOID:1.3.6.1.4.1.9.1.792>=12.2
IOS
Thanks-
Afroz
