PI 3.1 and Syslog Host
Ryan Curry
I'm hoping someone can give me some help here because I'm losing my freaking mind.  We are looking to move our syslogging to a new data center and I wanted to redirect my PI 3.1 instance to the new host.  I go into Administration > Settings > Logging.  From what I'm reading, there should be a "Syslog Logging Options" under this page where I have my syslog host set but I'm not seeing that tab at all.  I see "General Logging Options" and "SNMP Logging Options" but nothing more.  Has anyone else run into this??  I'm thoroughly confused at this point .....
Thanks all!
Ryan
Hi Ryan,
I could see prime Syslog(to forward systems logs as syslog) option under loggings, its in its own tab called "Syslog Logging Options"
have a look at the image.by the way I'm sure you know that this is not the syslog forwarding option for your devices
Cheers
Prabath
***Please rate all the useful posts***
-Prabath
Hi Ryan,
Cheers
Prabath
-Prabath
Thanks Prabath, I appreciate the response.  What's so perplexing is that I don't have that option on mine (see attached photo).  One thing to note is that I'm running 3.1 MR4, what version are you running by chance?
No worries, its 3.1.3 so one version behind. If they haven't depreciated that page and introduce the function elsewhere  I guess it could may very well be a bug,I cant see any caveats related on the release notes here yet. I suggest you log a TAC regardless
tried different browsers aswell??
-Prabath
Ryan Curry
FYI for anyone else having this issue, this is a bug in MR 4 that is supposedly fixed in MR 5.  I'm waiting for that release to validate it's actually fixed.
